AIMPBPL vs AIMPPL4
Topic: AIMPBPL vs AIMPPL4 (Read 6403 times)
AIMPBPL vs AIMPPL4
December 16, 2022, 15:26:48 »
xTen
Hi there,
What is difference between these two playlist formats? I want to export "*.aimppl4" with its songs to a folder then import them in AIMP android. AIMP android doesn't recognize "*.aimppl4" it just can find the "*.aimpbpl" playlists! Why it dosn't recognize the desktop version's playlist?! (I am aware of another playlist type like "*.pls, m3u"..., I don't want to use them)
PS: The Google captcha is disgusting, please disable it for submit a post. I am not a mathematician! Thanks
Last Edit: December 16, 2022, 15:32:45 by Soolo
Re: AIMPBPL vs AIMPPL4
December 16, 2022, 15:31:15 »
Карма: +1407/-191
use .xspf
https://www.aimp.ru/blogs/?p=1194
December 16, 2022, 18:31:18 »
xTen
Thanks...
February 17, 2023, 18:56:40 »
xTen
AIMP Android, can not find the tracks ("Absolute path files" is unchecked, xspf playlist) whenever I export PL from AIMP desktop! It says have to search to find the missing files!
March 13, 2025, 19:03:05 »
enrycone
Hi,
Did devlopers find out a way to sync AIMP playlist copy/pasting from PC to Android APP?
March 13, 2025, 19:18:07 »
Карма: +476/-74
https://www.aimp.ru/blogs/?p=1498&language=en
March 13, 2025, 19:21:43 »
enrycone
Thank you so much.
AIMPBPL vs AIMPPL4
