how to ignore folders
Topic: how to ignore folders (Read 2741 times)
December 05, 2022, 19:25:15 »
d4rt
Is it possible to exclude a subdirectory from the search when adding new files to the media library, like creating a .nomedia file in that dir?
Re: how to ignore folders
December 05, 2022, 20:48:51 »
Карма: +3225/-78
Yes, just "uncheck" required folder when selecting the folders to index
December 05, 2022, 21:52:19 »
d4rt
Ok, but suppose you had one main folder. Instead of checking all subfolders one by one except the one you don't want indexed you could just add the main folder with 'sub-folders' checked and let aimp do the work for you ignoring every folder that has a .nomedia file in it.
December 05, 2022, 22:54:43 »
Карма: +3225/-78
.nomedia is from Android world
December 05, 2022, 23:51:44 »
d4rt
The point is to have a way of ignoring a folder by the app on Windows. Git does that with .gitignore, so aimp could have .aimpignore for example. Would you consider implementing that?
December 06, 2022, 08:34:41 »
Карма: +3225/-78
Ok, I will think about that.
