One UI 5
Topic: [x] [1227] No cover in the notification area on Android 13 / One UI 5 (Read 13465 times)
October 19, 2022, 17:19:19 »
s/ash
Карма: +34/-1
The cover is not shown at all on Android 13 / One UI 5:
Also, when the file has no cover, AIMP will display the dark AIMP logo, even when the light theme is in use:
Last Edit: October 20, 2022, 09:13:36 by Artem
Re: [1227] No cover in the notification area on Android 13 / One UI 5
October 19, 2022, 20:55:27 »
Карма: +3214/-78
Its strange, your widgets does not look like standard multimedia widget in Android 13.
Quote from: s/ash on October 19, 2022, 17:19:19
Yes, our logo is always on dark background (in previous version, background was transparent, but Android 13 does not supports for that)
Re: [?] [1227] No cover in the notification area on Android 13 / One UI 5
October 19, 2022, 21:33:22 »
s/ash
Карма: +34/-1
This is the only type of notification style AIMP allows me to set on Android 13.
I tried downgrading to 1199, and the cover shows up in the notification:
October 19, 2022, 21:48:31 »
s/ash
Карма: +34/-1
I discovered the problem. It's this setting to show the album art on lock screen. If it's disabled, then AIMP will not show the art in the notification are either.
This only happens in Android 13, and only when using AIMP 3.30. 3.22 doesn't have this problem.
October 19, 2022, 23:22:29 »
Карма: +3214/-78
Thanks for research, I will check it
October 20, 2022, 09:13:32 »
Карма: +3214/-78
It seems this option will not work in Android 13 as it named, because Android 13 always take album art for notification from media session that used for lock screen too. I will disable the option.
One UI 5
