Pause/play from bluetooth media keyboard.
Topic: Pause/play from bluetooth media keyboard. (Read 9966 times)
September 01, 2022, 12:43:42 »
zax
Hi,
I am using AIMP 3.22 on android which is connected to Logitech K380 keyboard. This keyboard has media button for controlling next/previous song (these works) and play/pause (this does not work). I tried to find in the settings how to make play/pause buttons working with AIMP, but I could not find where I can set it up. Is this possible or currently not?
Re: Pause/play from bluetooth media keyboard.
September 02, 2022, 09:13:29 »
Карма: +3230/-78
Officially, our app does not supports for keyboards, but I hope that multimedia keys should work like headset keys.
September 02, 2022, 10:14:34 »
zax
If I try some other players, then the media play/pause buttons works. From the BT headset play/pause function works, but not from the media BT keyboard.
If you would like to add this feature I can be a beta tester.
Kind regards,
Zax
September 02, 2022, 10:37:33 »
Карма: +3230/-78
Refer to the "About" dialog of the app, and check the "enable logging" option. Now, type something with the keyboard and send the log file to me. Please, report to me a approximate time when issue was happened.
September 02, 2022, 10:46:48 »
zax
There are 2 logs:
- longer, with more media key pressed (next, previous, pause/play)
- shorter, with only play/pause keys pressed 10 times.
Thanks for helping.
Zax
September 06, 2022, 16:05:31 »
Карма: +3230/-78
First, it seems you has no command specified for "headset \ single tap" action (app handles the key press, but does not send anything to a service).
September 06, 2022, 17:26:28 »
zax
Looks like this was the issue (nothing set for the tap action). I did not connect this with the fact that it does not play as the BT headphones did work without this option to be set up. Thanks for helping!
September 06, 2022, 19:20:21 »
Карма: +3230/-78
You are always welcome
