Общее
General
Фагот
A question regarding AIMP tag editor
Topic: A question regarding AIMP tag editor (Read 11199 times)
August 19, 2022, 18:40:24 »
captainemo20
nder folder 1 there are 12 folders, under each one about 50 files. Let's say folder one is "Bach concertos", I'd like to change automatically all the files' album field to "Bach concertos" (their parent folder name) and I'd like the same action to be done throughout all the twelve folders, bach sonatas, bach suites etc, without doing it one by one.
This task is probably quite basic, I'd like to do the same thing with the artist field. Let's say under baroque folder, change all the folders under vivaldi, and bach, and geminiani etc.
How to do it?
Thanks.
Re: A question regarding AIMP tag editor
August 22, 2022, 22:01:48 »
Карма: +3220/-78
Just add your folders to the list of Advanced Tag Editor tool (main menu \ utilities \ Tag editor).
In this case, all files from these folders will be added to a single list.
Next, select all files in the list and check the mark next to "Album" field. Type the value and click "Save"
Общее
General
Фагот
