Incoming calls with wired headphones
Topic: Incoming calls with wired headphones (Read 11997 times)
August 06, 2022, 17:11:08 »
Loquenahak
Good afternoon.
There is an issue that I can't hear very well incoming calls while listening to music with wired headphones - it works well with normal speakers as well as in other plays such as Spotify and Podcasts.
OS : Android 12
Device : Galaxy note 3
Headphones: Sony MDR-ZX110
AImp ver. : Latest
Aimp is the best android player!
Thank you.
Best,
Last Edit: August 08, 2022, 14:49:46 by Artem
Re: Incoming calls with wired headphones
August 07, 2022, 10:20:16 »
Карма: +3195/-76
What state of audio focus settings?
Is the read phone state permission grant for the app?
August 07, 2022, 20:20:29 »
Loquenahak
Thank you for the reply.
- My audio focus setting is default: (1) YES (2) NO (3) YES (4) YES
- Yes, my aimp has both permission that (1) file and media (2) phone
More detail:
- While playing music with headphones on aimp, incoming calls from dialer, google dialer, whatsapp, skype do not ring (any other minor messengers such as Line, Kakaotalk are ok though)
- While playing music, changing ringtones does not play sound properly
- both the sounds are like noisy mixtures or battle between the music and the ringtone
- If playing with speaker, everything works fine
Thank you.
best,
August 08, 2022, 09:40:33 »
Карма: +3195/-76
What output method is used in AIMP? (Settings \ Sound \ Output)
August 08, 2022, 12:03:50 »
Loquenahak
My audio output setting is:
1. Auto
2. Auto
3. High quality
4. Forced 16 bit - Yes
5. No
6. No
August 08, 2022, 12:17:17 »
Карма: +3195/-76
Please try to set output mode to Audio Track instead of Auto
August 08, 2022, 12:38:10 »
Loquenahak
I have just tried Audiotrack.
The volume of ringtone is somewhat low, but it works well.
Thank you, Artem.
