AIMP 64bits issues
Topic: AIMP 64bits issues (Read 2943 times)
AIMP 64bits issues
August 02, 2022, 20:15:39 »
EICP
Hi,
I installed aimp 64bits 5.03 build 2397 for Windows 10 but i'm facing some problems.
When i right click on a music file, it doesn't show the aimp options (convert, add to playlist, etc), only "Open with AIMP". Also, it doesn't create separated playlist; it always opens on the default replacing what was there previously.
Thanks
Last Edit: August 02, 2022, 22:47:22 by Soolo
Re: AIMP 64bits issues
August 02, 2022, 21:15:42 »
Карма: +3207/-77
Please try to do following steps:
1) Uncheck all options in the "Options \ System \ Integration" page
2) Apply changes and close the application
3) Restart the computer
4) Remove the AIMP-ContextMenu.ini from С:\Users\<UserName>\AppData\Roaming\AIMP\ folder
5) Restore options state in the "Options \ System \ Integration" page
6) Apply changes
August 02, 2022, 21:26:13 »
EICP
That worked!!!
And regarding the playlists?
August 02, 2022, 21:58:41 »
sveakul
Карма: +81/-1
Preferences/Playlist/File Adding/General--When files are being opened-> Create New Playlist
You may need to do the same in the "Open files from external applications" section also depending on how you use it.
August 02, 2022, 22:05:10 »
EICP
Also worked!
Thanks for your help!
AIMP 64bits issues
