[+] [1199] letter – (not -) wouldn't recognized -> STATUS_OBJECT_PATH_NOT_FOU
Topic: [+] [1199] letter – (not -) wouldn't recognized -> STATUS_OBJECT_PATH_NOT_FOU (Read 12677 times)
July 14, 2022, 11:35:57 »
ntfs
Hi,
in my playlist some entrys use the letter
, which is not the letter
. Playing this files is not possible. At log it seems, that this letter would not be recognized.
For example the directory is
.\Musik\AIMP\Alben\Unheilig\Unheilig - MTV Unplugged Unter Dampf – Ohne Strom (Deluxe Version)
- but in log it seems, that AIMP tries to open an file
Musik/AIMP/Alben/Unheilig/Unheilig - MTV Unplugged Unter Dampf
Ohne Strom (Deluxe Version)/04 - Sage ja - MTV Unplugged.m4a
, which is not possible.
The files are stored at an SMB-fileshare.
Thanks for attention.
Last Edit: August 11, 2022, 09:59:29 by ntfs
Re: [1199] - letter – (not -) wouldn't recognized -> STATUS_OBJECT_PATH_NOT_FOU
July 20, 2022, 12:57:30 »
Карма: +3227/-78
I have tried to create playlist with same path from scratch and it seems all works fine.
May be, path has been corrupted somewhere else.
How you add the files to playlist?
Re: [?] [1199] letter – (not -) wouldn't recognized -> STATUS_OBJECT_PATH_NOT_FOU
August 09, 2022, 09:36:19 »
ntfs
I've create a playlist in WINAMP and saved it in playlist.m3u-file. Then i import the playlist in aimp ("load playlist") from smb share. Works fine for almost any file - except files with that directory.
I've added an samplefile at attachmend.
August 09, 2022, 09:42:12 »
Карма: +1407/-191
.m3u not work with unicode
use AIMP for Windows with .m3u8 or .xspf
or rename folder "-" symbol
August 09, 2022, 19:52:54 »
ntfs
Good to know. then this would cause the issue and it is not an bug from AIMP.
Thanks for checking and for developing AIMP.
edit:
P.S.: just tested. With m3u8 it works fine. thanks.
Last Edit: August 09, 2022, 20:07:45 by ntfs
