Update v5.03 build 2394 [Windows 10]
Topic: Update v5.03 build 2394 [Windows 10] (Read 3991 times)
July 12, 2022, 21:41:15 »
Salpeter
Hello, the update is breaking: „An error occurs while backuping the "C:\Users\PC\AppData\Roaming\AIMP\AlbumArts.Cache.db" file (98304). Cannot open file "C:\Users\PC\AppData\Roaming\AIMP\AlbumArts.Cache.db". The process cannot access the file because it is being used by another process.
Other program does not access. Cache deleted then file deleted. Directory and files have all read and write permissions. Does not help. Please do you have a solution?
Shorter way, program reinstalled.
Last Edit: July 16, 2022, 00:54:07 by Salpeter
Re: Update v5.03 build 2394 [Windows 10]
July 12, 2022, 22:50:17 »
Карма: +474/-74
Reboot PC?
July 15, 2022, 21:36:19 »
Salpeter
Thank you.
December 05, 2023, 01:36:31 »
pyxelr
Карма: +2/-0
📊 Data connoisseur | 💼 MLOps | 🌐 pawelcislo.com
Had the same issue today with the update to
v5.30.2531
. The solution was to
download
the installer (
aimp_5.30.2531_w64.exe
), and perform the update from here. There was even an option to skip the backup creation, although it still worked for me.
