Skin Editor, Skin Engine
Unsupported skin for old versions
Topic: Unsupported skin for old versions (Read 28446 times)
July 08, 2022, 17:40:47 »
Chonga2520
Карма: +8/-0
I was making a skin for android version v3.10 build 1052 using the skin editor version v1.23.153. When i opened my custom skin on my phone, i was surprised to see a message: "Custom skin that you have selected has unsupported version! Default skin will be applied"
I dont know how to fix this. And i want to continue using android version v3.10 because of the equalizer. Is there a version of the skin editor that is compatible with it?
Edit: Actually, can i have the file of skin editor version 1.22.121? that might work with v3.10 the most
Last Edit: February 06, 2024, 13:32:41 by Chonga2520
Re: Unsupported skin for old versions
July 08, 2022, 18:39:10 »
AJ
Тестер-Ветеран
Карма: +298/-8
AIMP Theme Editor 3.22.121 (GDrive)
Last Edit: July 08, 2022, 18:49:35 by AJ
August 01, 2022, 21:42:05 »
Chonga2520
Карма: +8/-0
Quote from: AJ on July 08, 2022, 18:39:10
Thank you very much Artem! Have a good day
