(Help) how to rename online radio m3u file?
Topic: (Help) how to rename online radio m3u file? (Read 3044 times)
June 25, 2022, 21:35:12 »
tarufetti
Карма: +1/-0
Hello. I have a custom list of online radios (m3u), and I have it in a playlist within Aimp.
What happens to me is that I only see the URL addresses of these radios, and it is difficult to navigate. So, I try to rename the file, but it is not permanent, since online radios show the songs that are playing at the moment, and the name that I put disappears.
What variant exists to build a list of m3u urls in an orderly manner within Aimp? Thank you.
Last Edit: June 26, 2022, 12:21:45 by Soolo
Re: (Help) how to rename online radio m3u file?
June 25, 2022, 21:53:25 »
Карма: +1406/-190
Stop play radio, rename.
June 26, 2022, 07:26:52 »
tarufetti
Карма: +1/-0
Hello. Already solved. It had nothing to do with Aimp, but due to my little knowledge I didn't know where to ask.
I learned something new, and that is to edit m3u lists with a text editor. It was very simple.
Thanks for replying anyway. All the best!
(I don't know if the post should be marked as "solved", or something like that)
