Lyrics BOX small text, same colors.
Topic: Lyrics BOX small text, same colors. (Read 3465 times)
June 23, 2022, 01:39:17 »
PapaiMark
First of all, I know how difficult is to create a software, so many people involved,
dedication, time and how pleasurable it is. And I thank you all for such a good player.
That said,
I took an entire screen shot so you can see what I see (full HD).
Lyrics.
How can I make it readable?
the font is too small and the color is the same from background, slightly brighter.
Is there a way to change it?
I know something about nsis and using an hex editor.
Btw, the default interface on v5, from my point of view
Lets say I use “Experience AIO” as suitable for me.
Also, I couldn’t find the lyrics box on the default skin.
I guess it is there, but I just didn’t find it.
Any help? (about lyrics font size, background and color)
Please?
Re: Lyrics BOX small text, same colors.
June 23, 2022, 02:00:26 »
sveakul
Карма: +81/-1
With the Bliss 4K skin, if you right-click within the Information Box which is where the lyrics are displayed (be sure "Information Box" is selected from the Menu button), you will see the ability to increase the size of the lyrics font. Lyrics must be showing first:
June 24, 2022, 20:48:39 »
PapaiMark
Thanks for the answer, sveakul.
It would be good if the developers insert this in the default skin.
I want to keep the "experience" skin so I will search for more options.
I will try to extract the lyrics using nsis script (if There is a way) and send it to a simple txt reader.
