Resetting Playlist Sorting to Original Default?
Topic: Resetting Playlist Sorting to Original Default? (Read 9109 times)
June 21, 2022, 03:25:01 »
Sigistrix
Up front, my Russian is horrible. Probably worse than Churchill's French. So, English, please. I would really appreciate it. (And I do wish my Russian were better. It's a fun language)
So. I went to tweak my playlist sorting, globally, to something that it turns out I don't want. But now, everything I do, including uninstalling AIMP and reinstalling it, does nothing to reset everything back to the original configuration at initial installation. I've done as best a deep dive as I can to find any way to reset anything back to its default original. Is there such a thing> And, if so, where is it? I've looked everywhere.
Any help would be greatly appreciated!
Using AIMP 3.22, build 1197, Android 11, OnePlus 8T+
Re: Resetting Playlist Sorting to Original Default?
June 21, 2022, 09:44:56 »
Карма: +3221/-78
Refer to app settings \ playlist \ default sorting, and select "none". Of course, already sorted playlist will not reset to original order, but playlists will not sort automatically anymore.
