Default plugin for TAK in AIMP 64-bit
Topic: Default plugin for TAK in AIMP 64-bit (Read 1997 times)
June 07, 2022, 02:46:47 »
sveakul
Карма: +81/-1
Great on getting beta 3 of the 64-bit tak_deco_lib.dll working fine with AIMP 5.03RC Build 2388!
My question is, when playing a TAK file and both the aimp_ffmpeg and tak_deco_lib plugins are active, what decoder is actually in use?
Re: Default plugin for TAK in AIMP 64-bit
June 07, 2022, 08:08:11 »
Карма: +3200/-77
I have removed tak support from FFmpeg build
