How to remove the small interface that un-minimize the main window of AIMP?
Topic: How to remove the small interface that un-minimize the main window of AIMP? (Read 3614 times)
May 30, 2022, 20:37:25 »
Solo Alien
There is a small square with a triangle in it that when you hover the mouse curser to the left side of the screen when the app is minimized, that will un-minimize the app if you click on it.
I was wondering how i can remove that and/or turn it off. Most of the other apps that I use has sidebar options menu which I use a lot, but i'm constantly bothered when that square pops.
Please help me, Thank you.
Re: How to remove the small interface that un-minimize the main window of AIMP?
May 30, 2022, 21:04:21 »
Карма: +3229/-78
undock the window from screen edge. click right mouse button on window caption \ normal mode
May 30, 2022, 21:07:04 »
Solo Alien
Thank you so much
