Suggestions
DennoN
TAK 64-bit tak_deco_lib.dll version 2.33 beta 1 now available
Topic: TAK 64-bit tak_deco_lib.dll version 2.33 beta 1 now available (Read 18887 times)
May 30, 2022, 20:33:26 »
sveakul
Карма: +81/-1
At this address:
https://hydrogenaud.io/index.php?topic=122519.0
I have unloaded aimp_ffmpeg and added the folder tak_deco_lib to Plugins with the 64-bit tak_deco_lib.dll inside and tested with AIMP 5.03 RC build 2387 64-bit; the few TAK files I have play perfectly.
Re: TAK 64-bit tak_deco_lib.dll version 2.33 beta 1 now available
May 30, 2022, 21:05:06 »
Карма: +3214/-78
Wow. Thanks!
May 31, 2022, 12:02:52 »
Карма: +3214/-78
It seems the decoder is so unstable for now. I have tested on my files, and some files lead decoder to crash.
May 31, 2022, 21:59:17 »
sveakul
Карма: +81/-1
Sorry to hear that! From the thread he seems to be actively working on issues with it so hopefully the next beta will be more stable. The only TAK files I have are ones I encoded myself from FLAC originals using Takc.exe 2.3.1 stable, options -e -p2 -ihs. These all play without errors in AIMP 64 with the new library.
June 01, 2022, 20:16:42 »
sveakul
Карма: +81/-1
He released Beta 2 of the 64-bit version today with SDK (same link), and this time none of my TAK files will play either--revert to Beta 1, and they play.
"New in Beta 2
The interface of the 64-bit decoder library contained a bug. This release brings a new library and a modified interface for the pascal version which is technically backwards compatible. The C interface remains unchanged. The SDK documentation has been updated."
June 02, 2022, 11:24:21 »
Карма: +3214/-78
I have updated interface API, but it does not solve the issue. As I can see, Tomas already found an issue, but fix was not published. Will waiting for new beta.
June 02, 2022, 19:59:40 »
sveakul
Карма: +81/-1
Beta 3 is available now,
https://hydrogenaud.io/index.php?action=dlattach;topic=122519.0;attach=22572
Artem, is the AIMP 64 with the new API you mentioned available as a nightly build?
June 02, 2022, 20:52:56 »
Карма: +3214/-78
Beta 3 still doesn't work. No, I don't publish it, because no reason
Suggestions
DennoN
