Adding SD card? AIMP not seeing it as far as I can tell.
Topic: Adding SD card? AIMP not seeing it as far as I can tell. (Read 8124 times)
May 29, 2022, 22:11:21 »
boe
Hello,
I just downloaded AIMP. I'm running a Galaxy S10+ with the current official firmware release. In AIMP, when I click on storage - add local folder it only lists all the folders that are at the root of my internal storage drive - my SD card is not listed (nor are any of the subfolders of the SD card). I have all my music on my SD card. MDplayer can access the files there on my phone so I know the phone sees it.
Last Edit: May 30, 2022, 07:05:15 by boe
Re: Adding SD card? AIMP not seeing it as far as I can tell.
May 30, 2022, 12:20:56 »
Карма: +3199/-77
Click the hamburger button to invoke a navigation menu. In menu, select your sd-card.
May 31, 2022, 06:34:57 »
boe
Sorry my bad- I should have posted this in the android section.
