Removal of Decimal in Duration Column
Topic: Removal of Decimal in Duration Column (Read 2572 times)
October 27, 2021, 05:27:17 »
HansInya
Hello,
Sorry if this has a simple solution I tried looking and couldn't see anything obvious..
I have just updated to version 5.0 build 2338 and noticed now the track duration has a decimal point added. Is there any way to remove the fractional digits? Its making everything a big blur of numbers so would like to keep it to just minutes and seconds if possible
I am using the Bliss4k skin if thats relevant
Thanks
Re: Removal of Decimal in Duration Column
October 27, 2021, 08:08:16 »
Карма: +3195/-76
This is milliseconds. It cannot be disabled now
June 02, 2022, 14:51:46 »
EvilDragon
Карма: +4/-0
I don't like this change at all. Please provide an option to remove the milliseconds from this column! Thank you
