Replay Gain & Peak Normalization manual, tutorial?
Topic: Replay Gain & Peak Normalization manual, tutorial? (Read 19126 times)
May 06, 2022, 22:03:47 »
MusicLover
Hi, I'm trying to find a Replay Gain and Peak Normalization manual or tutorial of AIMP for Android, but I could not find any help or link in the app or the AIMP website and forum.
Can somebody tell me where I can find it, or provide me a little description and advice to use these features?
Thank you so much for your help.
Last Edit: May 07, 2022, 21:00:25 by MusicLover
Re: Replay Gain & Peak Normalization manual, tutorial?
May 08, 2022, 09:01:37 »
Карма: +3233/-81
Both are volume normalization methods with different strategy:
1. Peak-based normalization takes a maximal peak as a target and increase/decrease a volume level to the target. In this case clipping is prevented.
2.
Replay Gain
works with perceived loudness of audio (~"average loudness"), so it tries to increase/decrease perceived loudness to target value (default is 89 dB sound pressure level). Clipping may happens.
