Move "Add to Queue" in Context Menu and/orReplace "Add to Windows Player list"
Topic: Move "Add to Queue" in Context Menu and/orReplace "Add to Windows Player list" (Read 3478 times)
April 15, 2022, 16:50:04 »
vondelphia.com
Карма: +1/-0
Hello from Philadelpia, USA!
May you please advise on how I can "save a click" and move "Add to queue" OUTSIDE of the submenu? Perhaps even replace "Add to Windows Media Player list" with AIMP? Maybe someone here secretly has a regedit merge file floating around on the PC and would share it?
Have a good day.
p.s. - great job with AIMP, I love it.... it's the best. You Russians man... fantastic developers!!
Re: Move "Add to Queue" in Context Menu and/orReplace "Add to Windows Player list"
April 15, 2022, 16:55:50 »
Карма: +3229/-78
Open the AIMP-ContextMenu.ini from С:\Users\<UserName>\AppData\Roaming\AIMP\ folder in notepad app and replace value of the "Cascade" key with 0 value. In this case, all commands will be displayed on root level. Additionally, you can remove unused commands if necessary
April 15, 2022, 20:29:35 »
vondelphia.com
Карма: +1/-0
Marvelous!
