How Do I play M3U Files in AIMP?
Topic: How Do I play M3U Files in AIMP? (Read 4243 times)
April 03, 2022, 17:25:55 »
woooyeah
Hello Guys, good night from South Korea.
I use AIMP for my PC (Windows 10), and Jetaudio for my Android smartphone.
Thing is, I make my own playlist with Jetaudio there nad export it. Then an playlist with M3U format gets created and then I can use this list in my Jetaudio. Here's the problem now, I want to share it, meaning play it with my PC with AIMP. So I transfer the file to the PC and put it in the music folder where all the songs in Jetaudio are there. In my figuration, it should works fine but it doesn't.....
I don't see why? That is my music listening style and I really want my playlists to be shared with two different machines and programs.
Do you guys see what's the problem and how to get it done?
Thank you always. Peace to be with ya.
Re: How Do I play M3U Files in AIMP?
April 03, 2022, 17:30:59 »
woooyeah
I mean, the problem is, I can open the playlist with AIMP but it seems like it can't find the songs.... Do you see? Pleaseee...
I like AIMP except this situation and the bugs with mini-display and etc..... I like the sound and the design...... F the program with the wierd name with numbers and Alien looking not-cool Icon. -ㅂ-//
April 03, 2022, 20:50:47 »
opl516
안녕하세요. m3u는 단순한 텍스트 파일입니다. 음악파일의 경로를 지정하는 이른바 재생목록으로서 기능하는데, 사용하고 계시는 안드로이드의 플레이어(Jetaudio)가 상대 경로로 이루어진 m3u 파일을 만들어주지 않는다면 서로 자동으로는 호환될 수 없습니다.
상대 경로와 절대 경로에 대해서는 m3u의 위키피디아 페이지를 보고 이해하시면 됩니다.
https://ko.wikipedia.org/wiki/M3U
어쨌든 메모장으로 m3u 파일을 직접 열어서 경로에 해당하는 부분, 이를테면 C:\music\1.mp3 C:\music\2.mp3 C:\music\3.mp3라 한다면 "C:\music\"을 통째로 공백으로 찾아바꾸기 하시는 것으로, m3u 파일이 있는 폴더 안에 있는 mp3 파일을 정상적으로 재생할 수 있게 될 거라 기대해볼 수 있겠습니다.
Hi, m3u is a simple text file. It acts as a playlist that specifies the path to the music file, but if your Android player (Jetaudio) does not create an m3u file with a relative path, it cannot be automatically compatible with each other.
You can understand what the relative and absolute paths are by looking at the Wikipedia page of m3u.
Anyway, you should open the m3u file directly in Notepad and check the corresponding part of the path, such as C:\music\1.mp3 C:\music\2.mp3 C:\music\3.mp3, you can search and replace "C:\music\" to blank and then play the m3u file in the folder. it works maybe.
Thank you
April 04, 2022, 16:33:32 »
woooyeah
감사합니다. 한국분이신거 같네요. 그럼 사실상 제트오디오에서 만드는 재생목록은 그냥 호환불가라고 생각하고 다른 방법을 쓰든가 해야겠네요. 감사합니다. ㅜㅜ
