request: Add custom color option in Color Schema.
Topic: Just a humble suggestion / request: Add custom color option in Color Schema. (Read 2484 times)
March 21, 2022, 07:40:55 »
syahdafahreza
Hello, can you add custom color input in the Color Schema section. It will look like this:
It will be more convenient if i can customize color without using the color slider above. Thanks~
Re: Just a humble suggestion / request: Add custom color option in Color Schema.
March 21, 2022, 08:31:37 »
Карма: +3229/-78
Player uses only H and S component from the HSL color space. So, it means that exact color code has no sense here.
March 22, 2022, 08:05:50 »
syahdafahreza
Hello, thanks for the reply. So, I still figuring out how this color code work. Here what i try so far:
For example, the color i want the player to change into (as shown below):
This is the initial look:
I try to change this in the configuration file (AIMP.ini), located in:
[C:\Users\%USERNAME%\AppData\Roaming\AIMP]
Into this, based from H, and S value from HSL color space above:
This is the result:
Is there any way to do so correctly?. Thanks
March 22, 2022, 09:08:14 »
Карма: +3229/-78
This is not a color code. Low byte is a Hue, high byte is Saturation
