[x] [2367] Sorting ignores full-width numbers
Topic: [x] [2367] Sorting ignores full-width numbers (Read 11481 times)
March 19, 2022, 03:34:52 »
Voxtopass
AIMP does not sort full-width numbers (commonly used in Japanese, for example) so tracks named with them are not handled correctly. Neither automatic or manual sorting by filename work when the files contain these numbers. Manually adding files through the "open files" in the AIMP logo is the only way to sort them correctly, I think because it uses Windows sorting to handle the files. I have tried "convert non-unicode strings" in the settings, just in case, and it doesn't fix it.
If you would like to test, and you don't know how to type these numbers, I'll type some below for you to copy/paste.
3
4
5
Attached is an image of a "sorted" playlist.
Last Edit: March 20, 2022, 12:22:24 by Artem
Re: [2367] Sorting ignores full-width numbers
March 20, 2022, 12:22:19 »
Карма: +3220/-78
Please try this build:
https://disk.yandex.ru/d/kBttagCTBWz_Uw
Re: [x] [2367] Sorting ignores full-width numbers
March 21, 2022, 00:06:49 »
Voxtopass
That works perfectly. Thanks for working on that.
