Parametric Equalizer
Topic: Parametric Equalizer (Read 10465 times)
March 07, 2022, 00:21:12 »
reddino
I would like to load in aimp the Autoeq Parametric settings for my headphone. I dont see any way too do that right now.
Any idea in the future to add this function?
Re: Parametric Equalizer
March 07, 2022, 02:41:46 »
sveakul
Карма: +81/-1
You could turn off the bulit-in equalizer, add a VST host DSP, and then add a Parametric Equalizer VST plugin to that. You can see in the image below I have added a VST host DSP plugin in AIMP's Sound Effects section, and am running VST plugins for an alternate equalizer and a limiter/compressor within an effects chainer. Easy enough to use a parametric EQ VST there instead with your chosen settings. Definitely a work-around but it does work.
March 08, 2022, 02:22:58 »
Карма: +1406/-190
https://www.aimp.ru/forum/index.php?topic=23675.0
