Skin Editor, Skin Engine
Button copy text to clipboard?
Topic: Button copy text to clipboard? (Read 28440 times)
February 21, 2022, 18:12:05 »
koelo
Завсегдатай
Карма: +12/-0
How to make a button which when pressed copies a custom text into clipboard?
Re: Button copy text to clipboard?
February 21, 2022, 19:30:51 »
Карма: +1408/-191
Какой текст?
February 21, 2022, 20:17:23 »
koelo
Завсегдатай
Карма: +12/-0
Quote from: Soolo on February 21, 2022, 19:30:51
Какой текст?
Just some text regarding my skin. For example lets just make it "abc".
February 22, 2022, 20:49:31 »
Карма: +3229/-78
Only TASETextDisplay and TASETextDisplayEx has the CopyToClipboard method that copies the text display's content.
Refer to CopyToClipboardHandler custom provider in the Charm skin
March 27, 2026, 00:21:10 »
heroclix
Карма: +8/-7
Is there any progress on this? i wrote a script to test it, but it’s not working. here’s the script i wrote:
procedure Execute(Sender, Arguments: TComponent);
var
S: string;
InfoTextObj: TComponent;
begin
InfoTextObj := FindObject('FInfoText');
if InfoTextObj <> nil then
begin
try
S := InfoTextObj.Get('DisplayValue');
except
S := '';
end;
if Arguments <> nil then
begin
Arguments.Set('DisplayValue', S);
Arguments.CopyToClipboard;
ShowMessage('Info Copied: ' + S);
end
else
begin
ShowMessage('Arguments empty: ' + S);
end;
end
else
ShowMessage('FInfoText not found.');
end;
March 27, 2026, 08:20:51 »
Карма: +3229/-78
What exactly does not work here?
March 27, 2026, 08:56:37 »
heroclix
Карма: +8/-7
There is an FInfoText component, but its displayValue cannot be copied; it constantly returns 'Arguments empty'
March 27, 2026, 09:56:17 »
Карма: +3229/-78
Quote from: heroclix on March 27, 2026, 08:56:37
FInfoText
What class of this component? What component invokes the script?
Reply #8 on:
April 04, 2026, 20:48:30 »
heroclix
Карма: +8/-7
no worries, i figured it out thanks
