AIMP for Android v4.30
[x] [1180] Трудно вытянуть левую панель
Pages:
All
Topic: [x] [1180] Трудно вытянуть левую панель (Read 15937 times)
Re: [x] [1180] Трудно вытянуть левую панель
Reply #15 on:
January 23, 2022, 10:43:51 »
Rfx9123
Завсегдатай
@Artem
Thank you for new alpha aimp_3.22.1180_Alpha_internal (2022.01.22 21-25), but swiping from right to left in the playback window to get to the track view of the selected playlist definitely doesn't work. Are there different programming guidelines for newer versions of Android? My audio player is running Android 8.1 and there is no newer version for it.
Reply #16 on:
January 23, 2022, 11:48:22 »
Карма: +3209/-78
In latest alpha
, I have rollback all my changes that was made for swipe gestures. Now it should work as it was in 3.21.1178. Is not it?
Last Edit: January 23, 2022, 12:05:34 by Artem
Reply #17 on:
January 23, 2022, 13:34:55 »
Rfx9123
Завсегдатай
Thank you, now I can swipe to see the track list.
If you see my first video with installed AIMP 3.20.1178 (
https://filehorst.de/d/eaDEassv
), I can swipe on playback window from the middle of my screen (area of the cover), but in your new alpha the effective sensitive area to swipe is above and below the cover image. The middle area of the skin with the cover is still not responding properly.
Addendum: The gesture control was active in the album cover area, although I don't need it. Now everything is OK.
Last Edit: January 23, 2022, 13:52:58 by Rfx9123
Pages:
All
