Love this skin!! But for some reason when I updated the player to 5.10.2408 Beta 2 some graphical glitches appeared, mostly to do with the buttons.Any ideas?
everything looks good.
Thanks a lot for checking. Must be a problem with my system then (I'm on Linux, but everything worked fine before).Just updated to the new version and reinstalled the skin and the issue is still there.Funnily enough I still prefer it to the other skins, even with messed up buttons )
maybe you need install this font
Fixed by downgrading the player back to 5.03 version :/ The new version of the skin works just fine.
Apologies if this has been asked many times already (I tried searching for it, but no luck): is it possible to change the background of the playlist and make it album cover art?
Hi, this skin is very nice, thank youCan you put the project file as well?
Идеальный скин: удобный, минималистичный, компактный, приятный во всех отношениях.Perfect skin: convenient, minimalistic, compact and nice.
Ty for nice skin! I used a4 and i installed m5.In previous versions i found there was option not slide for minimized window, but slow appears. And now i can't see option for it.
