AIMP for Android v4.30
Empty playlist is deleted when exit
Topic: Empty playlist is deleted when exit (Read 3648 times)
August 14, 2021, 01:20:56 »
circcc
Moreover, empty Default playlist is deleted if other non-empty playlist exist when exit too.
Is it normal or bug?
If it is normal, Is there an option to keep it from being deleted except for preimage?
This is my first time using AIMP(v5.00.2320 Beta3) and this is strange.
Last Edit: August 23, 2021, 14:29:12 by Soolo
Re: Empty playlist is deleted when exit
August 15, 2021, 01:12:13 »
Карма: +3195/-76
What reason to keep an empty playlists?
August 15, 2021, 14:22:36 »
circcc
It's like a folder. For example, put songs in the K-Pop playlist and leave it blank when you get tired of listening to it. Then put in new songs. If the K-Pop playlist is deleted every time it is left blank, it is annoying because it has to be recreated every time. I used playlist like this in winamp media library.
August 15, 2021, 21:14:49 »
Карма: +3195/-76
AIMP tries to keep you free of garbage
Quote from: circcc on August 15, 2021, 14:22:36
Oh, seems its a root of the issue.
December 18, 2021, 05:34:19 »
Exilio
I have a different perspective:
I have each album in its own folder within Playlists.
When I select Removal and Physically Delete Selected Files for a particular album, I *want* the <album_name> folder to be deleted also -- but AIMP does not delete it, and leaves me with a bunch of empty folders.
Can I change this behavior?
