Question about AIMP on Android HU
Topic: Question about AIMP on Android HU (Read 5751 times)
November 29, 2021, 12:48:51 »
PhantomDj
Hi.
I use AIMP on an Android head unit inside my car.
While I have most parts figured out, there's one thing that I don't know if it's a bug of AIMP or a preference I need to change.
My Steering Wheel Buttons (SWC) work within AIMP, but "Previous/Next" track are reversed.
I mean, pressing the "NEXT" button makes AIMP to play the previous track on the playlist, and pressing "PREVIOUS" makes it play the next track.
So, is there a setting for this or is it a bug ?
BTW: The buttons seem to work properly with other media applications (including controlling AIMP on my cell phone when it's connected via Bluetooth (A2DP))
Thank you!
