Option to disable track progress from the taskbar.
Topic: Option to disable track progress from the taskbar. (Read 3664 times)
November 23, 2021, 23:33:21 »
babashizz20
Hello. I recently have made the switch from VLC and have found AIMP to be far superior. I have configured AIMP to perform and look exactly how I wish it would. The only option which I have not been able to find, is disabling track progress from the app's taskbar icon. I have added a screenshot of what I mean to say, I hope it helps.
Last Edit: November 25, 2021, 14:47:47 by Soolo
Re: Option to disable track progress from the taskbar.
November 23, 2021, 23:58:20 »
Карма: +471/-73
See orange the checkbox on screenshot.
November 25, 2021, 14:38:57 »
babashizz20
Quote from: Алексей Долматов on November 23, 2021, 23:58:20
THANK YOU VERRRRRRY MUCH. It never occurred to me, to click on System and be prompted with different set of options. Thank you once again. Cheers.
