How do I disable the accent colour on the bottom bar
Topic: How do I disable the accent colour on the bottom bar (Read 2190 times)
November 10, 2021, 02:53:56 »
eileenthg
I'm a little bit lost in the settings... Where is the setting to disable accent colour on the bottom bar? I tried the skin for a while and I liked it a lot, but I now prefer not to have a big orange block at the bottom.
Re: How do I disable the accent colour on the bottom bar
November 10, 2021, 08:39:44 »
Карма: +1408/-191
November 11, 2021, 03:00:53 »
eileenthg
Found it. Thanks!
