pause buttons in Windows 10. Is a feature of AIMP?
Topic: 'Desktop overlay' play / pause buttons in Windows 10. Is a feature of AIMP? (Read 5018 times)
November 04, 2021, 02:31:57 »
aneurysm1985
I have just installed AIMP v5.00 build 2338 with Windows 10, and I am using the skin ZiX version 3.6.
One of the features that I like about Spotify's Windows 10 player is that whenever I use my keyboard to change the volume, there will be a 'Desktop overlay' that appears on the screen that shows the volume level, and the name of the song. (You can see what the Desktop overlay looks like
on this page
, in the image immedicately above the text
"We'll show you how to easily disable the Windows 10 Spotify popup"
This Desktop overlay also includes buttons for ⏮︎ ► ⏭︎. I find this really convenient as a way to press ⏸︎ or ► on a song, without switching into the Spotify software itself.
Just wondering if AIMP supports this 'Desktop overlay' feature? Are there particular skins that do so? If not, I would like to suggest this as a handy feature.
Last Edit: November 09, 2021, 01:40:39 by aneurysm1985
Re: 'Desktop overlay' play / pause buttons in Windows 10. Is a feature of AIMP?
November 04, 2021, 10:40:37 »
Карма: +476/-74
https://www.aimp.ru/?do=catalog&rec_id=1097
Using hotkeys for volume / track switching in programs (volume2 & etc) may disrupt or hide this window.
November 09, 2021, 01:40:01 »
aneurysm1985
Thanks. I just installed this plugin and it works perfectly!
My only suggestion is that this could be integrated into the main version of AIMP that users download and install, as I think it would be a good native feature to have. But am glad that it is available as an optional plugin for people like me who are willing to go searching.
