I am searching for a track I do not know the name, interpret, etc. of.
Topic: I am searching for a track I do not know the name, interpret, etc. of. (Read 4271 times)
November 03, 2021, 14:39:33 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
I am searching for a track I do not know the name, interpret, etc. of. But I approximately know the time Aimp played it. Is there a way to find it by the time the piece was played?
Re: I am searching for a track I do not know the name, interpret, etc. of.
November 03, 2021, 15:34:02 »
Карма: +476/-74
If offline and collect information:
Media Library - column "last playback"
If exist a tags and scobled with scrobling:
Go to scrobbler site.
November 03, 2021, 16:00:29 »
Biff
Карма: +4/-0
Great, found it. Thank you!
I had given that piece 5 stars (I was searching for), but after the update they have disappeared. If I remember it right, the stars / rating is not saved to the playlist but has an extra file / data base.
November 03, 2021, 20:22:30 »
sveakul
Карма: +81/-1
Biff: I also highly recommend the "Current Track Info to Any v1.0" plugin for keeping track of files played and radio stream tracks played by time and day, you get a customizable list like this:
2021.11.02 16:26:54 Ewigheim - Im Leib Der Wahrheit
2021.11.02 16:26:46 Indricothere - II
2021.11.02 16:26:30 Nemesea - Caught In The Middle
2021.11.02 16:26:11 In Strict Confidence - Morpheus
2021.11.02 16:25:46 13 Candles - Siren (The Vampyre In White Mix)
2021.11.02 16:25:41 Trial - Blut und Eisen (Whipermix 2001)
That way you don't even need to rely on scrobbling for that info.
https://www.aimp.ru/?do=catalog.download&id=358
November 03, 2021, 21:27:29 »
Biff
Карма: +4/-0
Ah, thank you very much! I have "CurrentTrackInfoToFile", without time, date, etc.:
What is the difference? Should I better use your one instead of the one I have?
I just added "| %Today()" to it.
November 03, 2021, 23:41:09 »
sveakul
Карма: +81/-1
Hmm, my interface looks different than yours, see it below. The version of the file CurrentTrackInfoToAny.dll I have is dated 11/19/2018, how about yours? Mine is the same as the one I sent you the link for, which I have attached below. I think you have the older version when it was called "Current Track Info to File" (from 2016) instead of "Current Track Info to Any". He re-started the version number to "1.0" when the new name version was released in 2018.
Last Edit: November 03, 2021, 23:53:30 by sveakul
November 04, 2021, 00:26:19 »
Biff
Карма: +4/-0
Mine is dated 04.01.19:
With yours you have unlimited entries of tracks, I have max. 1000.
Well, yes, so mine obviously is the older one.
