Record radio stream with start-stop time clock option
Topic: Record radio stream with start-stop time clock option (Read 4009 times)
September 27, 2021, 15:21:39 »
hdprene
Hi There!!
I often use the stream record option for checking my own stream or to record shows/streams by others. Is it possible to add a start-stop time clock record option to the internet radio capture page? Maybe this is a suggestion for a new plugin? Thanks for reading and answering! Regards, hdprene
Re: Record radio stream with start-stop time clock option
September 27, 2021, 15:42:40 »
Карма: +3214/-78
Yes, its implemented in AIMP5 on scheduler plugin side
September 27, 2021, 19:37:39 »
hdprene
Wow that's wonderful! Thank you very much!
October 02, 2021, 18:38:02 »
hdprene
Thanks again for implementing this.
Do you know when version 5.0 will be released?
October 02, 2021, 21:46:38 »
Карма: +3214/-78
Soon, I hope
October 13, 2021, 15:17:12 »
hdprene
Hello Artem, just downloaded the 5.2334 version. Congrats and thanks for implementing the recording scheduler! it works perfectly! It really solved an issue for me :-)
