AIMP for Android v4.30
difficulty using find misplaced files after editing library in explorer
Topic: difficulty using find misplaced files after editing library in explorer (Read 2021 times)
October 08, 2021, 17:35:32 »
earthyspirit
Reorganizing music library I've disconnected some files in the database via windows explorer
So in AIMP Library, I search for misplaced files...
There AIMP says files not moved are also missing along with moved ones.
I direct AIMP to search the correct folder to fix only the obvious part first.
It finds no replacement options.
I try finding all missing file replacement options by searching root of drive (containing only music)
instead of correct options AIMP found mistaken identities for all files.
Odd choices not at all the same.
Have I broken the database or something? Finding missing files was working fair enough before.
Re: difficulty using find misplaced files after editing library in explorer
October 08, 2021, 19:14:03 »
Карма: +3196/-77
Please, can you illustrate an issue on one of file via screenshots? Because, I don't understand what the issue
October 08, 2021, 20:58:45 »
earthyspirit
its alright. i finally deleted the library folders and reloaded the drive. It caused some of my playlists to lose the marks id given them even though the files mirrored those marks, reloading tags did not get the marks, only skipping through the tracks loaded them.
I realized the reason the library would not locate properly was due to path issues which had changed.
