Tag Editor/Discogs Issue
Topic: Tag Editor/Discogs Issue (Read 7897 times)
September 12, 2021, 07:00:27 »
thesouvenir
Hi everybody,
I've searched around and couldn't find an answer to this question. When I open a track (or a set of tracks) in the Aimp tag-editor and try to Find tag information on Discogs, I get this error:
"This operation requires authorization. You must login and authorize the AIMP app to operate it. After doing it, send your request again"
When I say "OK" the Tag Editor crashes.
I've logged into Discogs and searched for a way to add Aimp to it's allowed applications but can't find a way. Does anybody possibly know how I can get around this issue? Love the software (just started using it) and was hoping to get rid of Foobar and Mp3tag and just use Aimp, but this is frustrating.
Thanks for any help!
Re: Tag Editor/Discogs Issue
September 12, 2021, 21:12:57 »
Карма: +3229/-78
What is your version of player? Have you installed Microsoft Internet Explorer?
September 13, 2021, 02:35:18 »
thesouvenir
Thanks for getting back to me! No, I have Microsoft Edge instead (though I rarely use it, I use Firefox mostly). Do you need Internet Explorer for it to work?
I'm using Aimp 4.70, build 2254.
EDIT: I did open Internet Explorer, logged into Discogs and tried again. Still nothing (same problem as before). I've disabled my Firewall/Virus Scan and tried the same thing. Same result. Last.fm and Musicbrainz both work as anticipated.
Last Edit: September 13, 2021, 03:19:31 by thesouvenir
September 13, 2021, 08:48:05 »
Карма: +3229/-78
Please try with AIMP5 Beta, I have re-designed authorization process in it
September 13, 2021, 11:19:57 »
thesouvenir
Hi there, thanks for the suggestion. I did update to Aimp5 Beta, but the same error happens when I try to search for tags with Discogs. Not sure what the issue is, but if it's not happening with anybody else I'm guessing it's something to do with my set-up here. Strange.
September 13, 2021, 11:38:23 »
Карма: +1408/-191
September 13, 2021, 19:51:29 »
thesouvenir
Hi Soolo, thanks for the reply. When I press the box that you pointed out in your previous message/image, I get this error message.
September 13, 2021, 19:56:15 »
Карма: +1408/-191
"Save bugreport" and attach to message
Reply #8 on:
September 13, 2021, 20:11:33 »
thesouvenir
Here you go. Thanks!
Reply #9 on:
September 14, 2021, 11:38:55 »
Карма: +3229/-78
Please try on this build:
https://disk.yandex.ru/d/Wb-_x41DYOT8OA
Reply #10 on:
September 17, 2021, 01:25:40 »
thesouvenir
Hi Artem, thanks for getting back to me, but it appears I'm too late. The link you provided has expired. Sorry, I've been busy the last couple of days. Any possibility of a re-up?
Reply #11 on:
September 17, 2021, 08:03:50 »
Карма: +3229/-78
https://disk.yandex.ru/d/xT2JDHXWtpiiBg
Reply #12 on:
September 17, 2021, 23:49:29 »
thesouvenir
Hi Artem, thanks for re-uploading this for me. I've installed the de-bugged update you made available, but the tag-editor now crashes as soon as I attempt to open it (it sends me directly to a bug-report window). Here's the bug report, if you're interested. Thanks again!
Reply #13 on:
September 18, 2021, 13:11:19 »
Карма: +3229/-78
Yes, latest build of Tag Editor does not start on Windows 7.
Please, try following nightly build:
https://disk.yandex.ru/d/p99-4WT3u-nL1g
Reply #14 on:
October 05, 2021, 19:27:27 »
Карма: +3229/-78
Hello, have you tried the build?
