AIMP for Android v4.30
Is there a way to fetch composer data from last FM?
Topic: Is there a way to fetch composer data from last FM? (Read 2364 times)
July 21, 2021, 10:57:28 »
crystAlex
Hi guys,
I use AIMP all the time to listen to, and rip, new Cd's.
The only inefficiency at this point, is I have to manually add composer, year and album cover.
The last 2 ones are really just a small task, but composer can take some time. Is it normal that this data is not retrieved from Last.fm, or is this something I've set up incorrectly?
Thanks for the feedback!
alex
Re: Is there a way to fetch composer data from last FM?
July 21, 2021, 19:04:03 »
JD
Карма: +109/-3
IFAIK lastfm doesn't store composer data.
Use discogs or musicbrainz.
I'm talking about ATE, never used AIMP for ripping
August 01, 2021, 14:11:03 »
crystAlex
Alright, I'll try that! Thanks for the tip!
