Parameters on Lyrics tab for using local files as playlists
Topic: Parameters on Lyrics tab for using local files as playlists (Read 3376 times)
June 27, 2021, 00:19:15 »
houzjunkie
I currently have AIMP 4.70 installed on my pc and I have music files that are mixes which contains a number of songs in them. I make playlists in plain txt file format and store them in a different subfolder where my music files are stored i.e. Root folder is called WBMX and I have subfolders "FINAL" where the final mp3 is stored and "TXT" where the playlist is stored. They would then show up in the Information Box under the music file info. I had figured out how to get AIMP to pull the info from the text files in this folder layout by using the "find in folder" option on the Lyrics tab. However I had to reimage my PC and I forgot what parameters/switches were used. I took me forever to figure it out the first time. Would anyone know what parameters to use?
Thank you
HouzJunkie
Re: Parameters on Lyrics tab for using local files as playlists
June 28, 2021, 05:30:27 »
ss.pl
Карма: +162/-9
Quote from: houzjunkie on June 27, 2021, 00:19:15
%filename% - ищем текст лирики (*.txt; *.lrc; *.srt) рядом с аудио-файлом
../%filename% - ищем текст за пределами [ ../ ] папки "final" (где лежит твой «*.mp3»)
../txt/%filename%
- ищем за пределами папки "final", но только в директории "txt".
Это твой случай
../txt/other/%filename% - ищем за пределами "final", в директории "txt" во вложенной папке "other"
