AIMP add folders from Onedrive App
Topic: AIMP add folders from Onedrive App (Read 7209 times)
June 15, 2021, 00:00:02 »
nejcek74
I am trying to use AIMP to listen my music files that I have synced with my phone with Onedrive Android App.
1. if I go to Onedrive app => select file => play with AIMP => the AIMP opens , but I get this error message:
"unable to load and play file Error: file was not found" (first there is a baloon message showing path to the file, but it is gone to fast for me too read)
2. if I go to AIMP app => default playlist, I see added files, but I cannot play them the same
3. if I go to add files, I cannot find where the Onedrive folder with music is.
Is what i wanted to do possible at all? What is the best way to add my whole folder structure inside the Onedrive Music Folder?
Re: AIMP add folders from Onedrive App
June 15, 2021, 10:21:25 »
Карма: +3227/-78
To play music from OneDrive cloud use built-in clouds support.
June 15, 2021, 12:30:09 »
nejcek74
Thank you for your reply.
I guess you are talking about:
default playlist => add.... => add files => add storage => windows shared folder
I add "
https://onedrive.live.com
" as a server, and than using my username and password to authenticate, but it fails to connect: "jcifs.smb.Smb.Exception......"
is this the right way? I am sorry, but it is hard to find any information.
additional question: if I am going this way, will AIMP be able to play music also when I am offline, benefiting from the fact that my onedrive music files are set as "available offline"
June 15, 2021, 12:55:41 »
Карма: +3227/-78
Oh, you are talking about mobile version... I afraid mobile does not support clouds
