Suggestions
DennoN
Tempo slider in main window
Topic: Tempo slider in main window (Read 14427 times)
June 09, 2021, 13:01:01 »
mikethehike
Hello,
is it possible to add a tempo-slider to the main skin? I need it for a dance school to slowdown the music for dancing.
Mike
Re: Tempo slider in main window
June 09, 2021, 14:15:28 »
Карма: +477/-74
You can create your a skin. It's needless for everyone users.
January 17, 2022, 13:35:40 »
on
I know it's an old thread, but I loose few hours to search for decision of that problem. Aimp v2.61 has tempo and speed sliders in default skin.
Actually there are already made skins, that can be used with v5 AIMP:
https://www.aimp.ru/?do=catalog&rec_id=902
https://www.aimp.ru/?do=catalog&rec_id=1216
and maybe few others.
January 25, 2022, 23:28:25 »
brellaumpixel
All 4 of the
RealPlayer SP Plus
skins by memo-se have a tempo slider in the main window
check them out they're quite good
https://www.aimp.ru/?do=catalog&rec_id=1102
Suggestions
DennoN
