windows blocks access to AIMP
All
Topic: windows blocks access to AIMP (Read 12376 times)
June 07, 2021, 03:45:40 »
JimFlasch
Карма: +0/-1
Every so often Windows 10 unexpectedly shits down AIMP if it's open and refuses to let me reopen it, instead giving me a message saying "Windows cannot access the specified device, path, or file You may not have the appropriate permissions to access them." The only way I can get AIMP working again after this pops up is to restart Windows, which is annioying. Why the hell does Windows do this to me and how do I stop it from happening again.?
Re: windows blocks access to AIMP
June 07, 2021, 08:14:06 »
Карма: +3229/-78
What is your antivirus?
June 08, 2021, 09:10:30 »
JimFlasch
Карма: +0/-1
Avast.
June 08, 2021, 09:21:27 »
Карма: +3229/-78
Update databases, Avast already have fixed this false positive unlike ESET
June 08, 2021, 21:49:53 »
JimFlasch
Карма: +0/-1
Avast updates automatically.
June 09, 2021, 02:08:40 »
sveakul
Карма: +81/-1
Try putting the entire AIMP folder hiearchy into Avast's exclusion/whitelist. Avast is a known bad actor with another major music player as well.
If that doesn't solve the problem, AND you don't already have the Portable version of AIMP, switch to the Portable and install it in a folder outside of the Windows "permissions" areas, like C:\AIMP. Whitelist the folder in your AV.
July 21, 2021, 02:54:24 »
JimFlasch
Карма: +0/-1
So far, no occurrences of the above problem with the portable version. However, it has started (as of yesterday, 7/19) started freezing on me ten minutes after I open it.
August 07, 2021, 04:13:05 »
JimFlasch
Карма: +0/-1
Ok, so after a period of working correctly again, AIMP has once more (as of 8/5 and continuing on 8/6/2021) been freezing up on me, usually after about ten minutes, and not unfreezing. Why?
Reply #8 on:
August 08, 2021, 03:40:56 »
JimFlasch
Карма: +0/-1
Still crashing today, once after three minutes' playing time, and again (after a reinstall) after about 9 minutes.
Reply #9 on:
August 13, 2021, 03:31:58 »
JimFlasch
Карма: +0/-1
After a few days of not using AIMP, I tried it again, and it froze again after about 10 minutes.
Reply #10 on:
August 17, 2021, 03:34:35 »
JimFlasch
Карма: +0/-1
The latest releases of AIMP versions 4 & 5 (build 2254 and Beta 3, build 2320 respectively) are STILL freezing up after roughly ten minutes of playtime! PLEASE fix this bug!
Reply #11 on:
August 17, 2021, 08:09:21 »
Карма: +3229/-78
If you still using v5.00 beta 3, please run following tool when app hangs, it should dump state of app
https://yadi.sk/d/LChU4E7zjYuf8
Reply #12 on:
August 21, 2021, 03:55:13 »
JimFlasch
Карма: +0/-1
Ran the program. Here's the report dump.
Reply #13 on:
August 21, 2021, 13:08:29 »
Карма: +3229/-78
Seems it freezes on attempt to save playlist to app data folder. If you suspend your antivirus, does issue still happens?
Reply #14 on:
August 23, 2021, 03:26:24 »
JimFlasch
Карма: +0/-1
Yes.
All
