Issue with playback priority on Android 11
Topic: Issue with playback priority on Android 11 (Read 7563 times)
May 19, 2021, 18:17:57 »
Lackadaisy
Hi,
So, my phone recently upgraded to Android 11, and I found an issue with the new grouped together media controls in the notification shade (or at least with the new way media is handled in this android version).
Let's say that I have played a music file through AIMP and then paused it - the media controls in the notifications are now clustered together with other media apps that I have opened. Now for example I switch to my podcast app. I play a track, listen to it via bluetooth headphones, and then pause through the headphones themselves. If i now press the resume button on my headphones, instead of resuming my podcast, AIMP takes over and starts the track that I had previously paused. This happens only with AIMP, and with different bluetooth peripherals.
I tried different combinations of settings in the "sound" and "playback" sections, with no luck. Am I missing something, or is this a behaviour that needs fixing?
Thanks in advance for any help
Re: Issue with playback priority on Android 11
April 19, 2022, 22:12:45 »
Карма: +3221/-78
This behavior is under Android control.
I suggest you to check the the "ignore external commands if player is not running" option (AIMP Settings - Integration).
In this case, player will ignore all external commands if app is closed. So, Android will forced to send command to next app.
