Error with File Location
Topic: Error with File Location (Read 2441 times)
April 23, 2021, 18:55:33 »
PatateDouce
Hello,
I have this message when I click on "File Location..." item.
This file does not have a program associated with it for performing this action. Please install a program or, if one is already installed, create an association in the Default Programs control panel.
I have this message since I've changed by mistake a setting in the Q-Dir explorer. I checked the registry. Everything seems OK.
There is certainly a setting somewhere to restore but I don't know which one.
Thanks for your help. And congrats for AIMP !!!
Re: Error with File Location
April 23, 2021, 19:03:29 »
Карма: +3229/-78
I have no idea how to restore it too. We uses Windows API to invoke file explorer withit the file directory
April 23, 2021, 19:28:36 »
PatateDouce
Thanks for your reply.
Could you give me the line of code ? Maybe that give me a direction to resolve the problem.
April 23, 2021, 21:18:07 »
Карма: +3229/-78
I use the SHOpenFolderAndSelectItems function
April 25, 2021, 23:26:02 »
PatateDouce
Thank you ! I will keep looking.
April 30, 2021, 11:32:29 »
PatateDouce
Hello, I resolved my problem. It was enough to clear the value of HKEY_CLASSES_ROOT > Folder > Shell > (Default). Even if the value is "none", you have to clear it.
April 30, 2021, 12:24:10 »
Карма: +3229/-78
Thank you for sharing your solution!
