Add songs to multiple playlists without multiple copies?
Topic: Add songs to multiple playlists without multiple copies? (Read 4391 times)
April 19, 2021, 19:38:21 »
azelira
Hi, apologies if this has been asked before, I couldn't find anything about it anywhere. I finally figured out that you can make folders in order to keep track of playlists on AIMP for android. However, I like to have one playlist that contains ALL my music. I found that if I try to add one song to multiple playlists, my "Everything" playlist ends up with multiple copies of the song. Is there a way to have a song exist in multiple playlists without having to make multiple copies of the file? Or is the only way to have an "everything" playlist to create a separate folder that contains another copy of every song?
Re: Add songs to multiple playlists without multiple copies?
April 20, 2021, 08:16:23 »
Карма: +3229/-78
Hm, but AIMP for Android does not allow duplicates in playlist. Are playlist items have a same file path?
May 19, 2021, 18:22:16 »
azelira
After starting over and trying again I wasn't able to reproduce the problem again, so I must have just messed something up the first time I did it.
