tags (lyrics) plz help
Topic: tags (lyrics) plz help (Read 1791 times)
April 14, 2021, 05:32:56 »
pablo5p5
hey guys im trying put lyrics to my songs with the TagEditor, my problem is when i search the lyric automatically there is ok but problem is this here i put an example:
I lay awake at night and pray\nNot to see the light of day\nI wonder how to behave right\n\nHe has left me such a mess\nCounting to protest\nMind can't get no rest\
every / is an Enter there is an option to change this to the TagEditor to modify and see the lyric like this:
I turned my back
You were gone in a flash
Like you always do
You've always gone off
Somewhere else
And when the phone rang
And I thought it was you
And I sprung like a kid
Who just got out of school
But it's almost
Always never you
Never you
I scream like a child
My insides went wild
Re: tags (lyrics) plz help
April 14, 2021, 07:09:59 »
sveakul
Карма: +81/-1
Are you using the "stock" aimp_webLyrics.ini file supplied with AIMP, or the one with modifications by sabadell66? Try using the latter one (attached, extract it into the AIMP/Plugins/aimp_webLyrics folder letting it overwrite the existing one). That said, I have seen MusixMatch lyrics found with the return characters shown as you describe in the "raw" Lyrics tag in Tag Editor, but that show just fine with the appropriate breaks in the Information Box window display when the song is played.
I'm assuming you are using AIMP 4.70 build 2242 or higher.
