Grand parent directory %FileParentDir
Topic: Grand parent directory %FileParentDir (Read 3487 times)
March 17, 2021, 14:38:58 »
mathiross
Hi everyone,
is there a syntax to obtain the second or third parent directory?
For exemple, in this filepath:
folder2
/folder1/file.mp3
It would return "folder2" for the second directory
If it doesn’t exist, would it be possible to add the syntaxes %FileParentDir2 %FileParentDir3 %FileParentDir4 ... ??
Thanks for help
Mat’
Last Edit: March 17, 2021, 15:00:21 by mathiross
Re: Grand parent directory %FileParentDir
March 17, 2021, 18:27:51 »
Карма: +3196/-77
Ok, I will
March 17, 2021, 21:18:34 »
mathiross
Excellent ! Thanks a lot !
I forgot to tell you that I especially need this new syntax for the Aimp converter but I suppose it will anyway affect both.
Have a nice coding and thanks again
Mat
May 19, 2021, 13:26:14 »
mathiross
Hello here !
Some news of this function?
thx,
Mat
May 19, 2021, 13:26:29 »
Карма: +3196/-77
I afraid no
May 19, 2021, 13:42:26 »
mathiross
Ok, no worry !
December 05, 2021, 09:44:28 »
mantotheworld
Are there any new updates regarding this function?
