Suggestions
DennoN
profile folder
Topic: profile folder (Read 7820 times)
profile folder
December 30, 2020, 18:11:13 »
pantau
Карма: +1/-0
It would be nice to be able to change the location of the profile folder. I'm using a dual-boot system, so it would be good if I could put the profile folder could not on the system drive.
Re: profile folder
December 30, 2020, 19:35:53 »
Карма: +3219/-78
You can use sym links for doing that.
Re: profile folder
December 31, 2020, 01:41:18 »
pantau
Карма: +1/-0
My dual boot is Windows 7 and W10. When I boot one, the other doesn't have drive letter, to disable any access to the files.
Re: profile folder
December 31, 2020, 02:43:10 »
Карма: +473/-73
Try use portable install, when profile folder same player folder.
Re: profile folder
December 31, 2020, 12:59:32 »
pantau
Карма: +1/-0
Then I will loose all my settings?
Re: profile folder
December 31, 2020, 13:20:58 »
Карма: +473/-73
Why? You can copy user setting in common portable version.
Re: profile folder
December 31, 2020, 13:22:24 »
pantau
Карма: +1/-0
But can I transfer it from the installed version to the portable version?
Re: profile folder
December 31, 2020, 16:36:03 »
Карма: +473/-73
Yes. You can move/copy settings folder from AppData to AIMP portable folder (AIMP\Profile).
Re: profile folder
Reply #8 on:
January 01, 2021, 14:00:52 »
pantau
Карма: +1/-0
Apparently setting on the portable version don't get preserved as well as on the installed version:
"Attention! This app edition has no installer that means it may not import settings from previous versions correctly. So, we do not recommend to install this version over app of previous generation (v4.60 or older)"
Is there a reason why you don't wont to make the location of the profile folder changeable? I use this features in most of my programs, and it help me to access the same profile from both boot partitions.
Re: profile folder
Reply #9 on:
January 01, 2021, 19:33:26 »
JD
Карма: +109/-3
"no installer" and "portable" are not the same
Suggestions
DennoN
profile folder
