AUTO PAUSE WHEN OTHER SOFTWARE SOUNDS
Topic: AUTO PAUSE WHEN OTHER SOFTWARE SOUNDS (Read 3492 times)
November 28, 2020, 02:12:30 »
Iyakimaru
I found a plugin that is only compatible with iTunes on MacOS, it allows to pause the music when another program emits sound, for example: when you open a video in the internet browser, the audio of the video is heard and the music is paused; when you stop the video, the audio stops playing and the music resumes after a couple of seconds. It works the same with any software that suddenly emits sound, you can configure which applications to ignore (whatsapp web notifications) and how long to wait before resuming music playback. I want to know if there is something similar for AIMP for Windows.
PS: I found mute.fm which is a freeware that activates MUTE when other software is playing, but the playback continues even if I don't hear it.
