How too handle too many albums in the library?
Pages:
All
Topic: How too handle too many albums in the library? (Read 10119 times)
Re: How too handle too many albums in the library?
Reply #15 on:
May 03, 2021, 18:14:16 »
verbal
Завсегдатай
Карма: +2/-0
Same over here..
I didn't notice improvements regarding ML performance...It's still laggy...
I'm aware that my library is too big... I'm a music collector and I'm not using player only for listening but also for organizing.
I have around 420 000 files at the moment, Local.adb is around 190 Mb.. I have 1 local and 1 external hard drive attached.
I have tried everything to speed up things.. reducing the number of the files in lists, reducing numbers of the list.. plugin out external drive.. nothing showed results, just this method I've mentioned above... and when I do so player runs smoothly... no matter where are the files stored and how many of them are in the playlist...
Don't want to sound negative, you guys did an amazing job with this player.. I just assume that there are not so many people with large libraries .. so you might not be aware of this problem... just want to support and help with my feedback if it's possible.. cheers
Reply #16 on:
May 03, 2021, 20:31:03 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
No no, I absolutely would not assume this but the opposite, there must be many having huge albums / libraries. If you look around in music forums alone, you would notice that, really unbelievably extrem big collections. I assume, I have about 200.000 to 400.000 albums or even more on different drives but it appears to be impossible to add them to a music library so I use catalog programs to list the albumes / tracks, etc. The scan of Aimp I mentioned here yesterday or before became so slow after about 200.000 tracks / files (not albums) that it added a single track per second only to the lib and later crashed (or whatever it was).
So I would be happy to just get the albums on my drive always running / connected added to the library.
Pages:
All
