playlist when disk changes
Topic: playlist when disk changes (Read 2572 times)
November 09, 2020, 15:40:05 »
reddino
I changed my computer.
How do I tell the playlist that it should no longer look on disk D but on disk C)?
Now my playlists is getting always this message: File was not found.
The preimage doenst work, if i mark the folder Aimp load all the files inside the playlist....
Re: playlist when disk changes
November 09, 2020, 16:22:30 »
s/ash
Карма: +34/-1
I don't know if there is a nicer way of doing this, but one possible solution is to open all playlists in a text editor and replace all (Ctrl+H) "D:\" with "C:\".
You can use something like Notepad++ and do this, at the same time, for all playlists. Notepad++ offers a portable version which does not require installation, if you don't want to install it.
Of course, if your path was something like "D:\Music\" and now you have "C:\Uers\username\Music\" then replace the whole modified path. Process is the same. Just create a backup of your playlist files before you do this. Also close AIMP while you modify them.
